Thread: Arial Narrow as standard font
    2002-04
    154
    Default Arial Narrow as standard font
    I'm setting up out co's title blocks using 2005. I'm wondering if anyone knows why I might stay clear of using Arial Narrow as our standard. I've read the post on the problems with bolding this font, but don't see any others.
    One problem that I experienced using 2002 was when I created a text mask. Everything displayed correctly on screen, but the plots always came out without the font fill. I tracked (..actually this forum tracked..)the problem down to having the 'hide plot' set to 'yes' for the viewports in the properties manager.
    This same example using 2005 and a background mask with the dimensions produces the correct results.
    Just wondering if there are any other lurking problems.
    Jason
    2001-12
    St. Louis
    5,319
    Unhappy Re: Arial Narrow as standard font
    Quote Originally Posted by jkipfer
    Jason
    ~shrug~ pretty quiet on this post? I hope that means there isn't much wrong with the idea.
    I don't know of problems, but, that could also be because I've not used arial narrow that much to notice.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    Turlock, CA
    5,706
    Default Re: Arial Narrow as standard font
    The last time I tried using ttf fonts in my titleblock (admittedly it was a few years ago), the performance was terrible. There was a known problem with the display manager when ttf's were nested entities. Don't know if its still a problem since I've just stayed away from ttf's in my titleblocks. I also had the same unpredictabilty with fills back then. Another reason I stayed away from embedding ttf fonts in blocks.
    C:> ED WORKING....
  1. 2012: Non-annotative text (Arial Narrow Mtext/Dtext) is not visible
    By DCarch in forum AutoCAD Annotation
    Last Post: 2011-11-04, 01:57 PM
  2. Need SHX font to replace Arial.ttf
    By jrebennack in forum AutoCAD General
    Last Post: 2009-06-22, 06:05 PM
  3. Arial Bold and Arial Narrow Bold shx files
    By briand.87290 in forum AutoCAD Customization
    Last Post: 2008-03-13, 12:10 PM
  4. Odd font issues with Arial Narrow ttf
    By ehomeier.52231 in forum AutoCAD General
    Last Post: 2007-12-17, 05:44 PM
  5. Does everyone have Arial Narrow?
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2004-08-05, 06:43 PM
