Thread: Riser Dropper Tag
    2006-08
    58
    Default Riser Dropper Tag
    I've created a riser/dropper tag for pipes in my building similar to the picture attached. The tag shows the service on the top and the size(diameter) of the pipe on the bottom. The size label is just reading of the size parameter of the pipe.
    What i want to know Is there any way of making the 'mm' and the diameter symbol to not show up in the tag?
    Cheers,
    Bren
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Default Re: Riser Dropper Tag
    Bren,
    There should be a way to do both of these, I just don't have a lot of time right now (making videos for my blog) to test.
    1. Set the Unit Symbol field to "None" on your "Pipe Size" Project Unit. =Settings ->Project Units -> Piping Discipline -> Pipe Size. See attached.
    2. In the Mechanical Settings dialog, under Pipe Settings, there's a Field called "Pipe Size Suffix", get rid of the Diameter Symbol there. See attached image.
    HTH,
    Kyle B
    Product Line Manager
    Revit Services
    Smart Questions = Smart Answers
    2006-08
    58
    Thanks once again Kyle, Big help. I now have it looking the way i want.
    Cheers,
    Bren
  1. 2012: About Workflow, Riser/Dropper and Quantities
    By Danoposada320107 in forum Revit MEP - General
    Last Post: 2012-02-15, 10:18 PM
  2. Content Brower Eye Dropper not working?
    By Dr._House in forum AMEP General
    Last Post: 2010-03-02, 08:41 PM
  3. Riser UP/DOWN display
    By ekolto in forum AMEP General
    Last Post: 2008-10-14, 05:36 PM
  4. Content Browser & I-Dropper
    By scompton in forum ACA General
    Last Post: 2008-06-28, 08:47 PM
  5. DBs in riser diagrams
    By cwjean76 in forum Dynamic Blocks - Technical
    Last Post: 2007-12-11, 09:55 PM
