Thread: Scaling
    2005-01
    58
    Default Scaling
    All,
    I have just started using 2008 recently and have found when I wish to adjust a viewport scale, I have a whole bunch of new scales instead of the nom of 1:1, 1:2, 1:5 and so forth. This happens again when I am about to plot. Most occasions though we use our page setup but when I need to plot just a window, I have trouble.
    What I am getting at is there a way to turn off, delete or get-rid-of those excess scales that I do not want?
    I appreciate the help.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,015
    Default Re: Scaling
    Try SCALELISTEDIT.
    For some reason I thought that was disabled in 2008 but I just tried it and the command still works.
    Jeff Paulsen
    2002-04
    Colorado
    2,015
    Default Re: Scaling
    I just remembered what changed in 2008. The scale list is saved in the drawing in 2008. In previous versions it was saved in the registry under the users windows profile.
    I did a quick test and it appears that when you insert a drawing the scales are also inserted.
    Jeff Paulsen
    2002-04
    Colorado
    2,015
    Default Re: Scaling
    There is a Reset button in the Edit Scale List dialog that restores a default set of scales.
    Does anyone know where the default list is stored and how it can be modified?
    Jeff Paulsen
    Tallahassee, FL
    3,259
    Default Re: Scaling
    Go to: http://discussion.autodesk.com/threa...hreadID=598934 and look for ScaleListDel.lsp Updated version (0.7) by Steve Johnson. Great tool!
    I added "SCALELISTDELALL" to my menu.
    Customized it for my needs adding code for my Scale List commands ""SCALELISTCIVIL and "SCALELISTCIVILTEMPLATE".
         (defun C:SCALELISTCIVIL ()
          (scaledel_smart_reset)
          (prompt "\nDeleting existing unused scales...")
          (scaledel_wcard "*")
          (prompt "\nCreating civil scales...")
          (scaledel_create_civil)
        ) ; End C:SCALELISTCIVIL
        (defun C:SCALELISTCIVILTEMPLATE ()
          (if (= (scaledel_warning) "Yes")
            (progn
              (prompt "\nDeleting all existing scales...")
              (scaledel_all_unsafe)
        ) ; End C:SCALELISTCIVILTEMPLATE
    ;; *** Note: several uncommon scales have been commented out.
    ;; Delete the leading semi-colon to make a scale active.
    ;; You can comment out an unwanted scale by placing a semi-colon at
    ;; the start of its line.
        (defun scaledel_create_civil ()
          (scaledel_create_scales
    ;          ("1:1" "1:1")
    ;          ("1:2" "1:2")
    ;          ("1:3" "1:3")
    ;          ("1:4" "1:4")
              ("1:5" "1:5")
              ("1:10" "1:10")
              ("1:20" "1:20")
              ("1:30" "1:30")
              ("1:40" "1:40")
              ("1:50" "1:50")
              ("1:60" "1:60")
              ("1:100" "1:100")
              ("1:200" "1:200")
              ("1:300" "1:300")
              ("1:400" "1:400")
              ("1:500" "1:500")
              ("1:600" "1:600")
              ("1:1000" "1:1000")
              ("1:1/4 mile" "1:1320")
              ("1:1/2 mile" "1:2640")
              ("1:mile" "1:5280")
        ) ; End scaledel_create_civil
    Good Luck,
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
    2002-04
    Colorado
    2,015
    Default Re: Scaling
    I found out the default scale set is stored in a compiled DLL so there's no good way to modify it.
    Thanks for the link to the lisp routine Tom. That looks like it will be very handy.
    Jeff Paulsen
  1. Image scaling
    By charliep in forum ACA General
    Last Post: 2006-06-21, 02:44 PM
  2. Scaling
    By leon.r in forum Revit Architecture - General
    Last Post: 2004-10-13, 01:43 PM
  3. Scaling
    By ihammerhands in forum Revit Architecture - General
    Last Post: 2004-08-26, 03:20 AM
  4. Scaling?
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2004-08-05, 12:25 AM
