Thread: unhandled access violation reading 0x0004 exception at 644fee80h
    Unhappy unhandled access violation reading 0x0004 exception at 644fee80h
    after invoking the copy with base point command then tried to paste the objects, i get the a fatal error message. i tried to wblock out the objects, purge, audit, etc.... no change.... the drawing just hates the command and throws me out before closing acad. What is wrong with the drawing? it was produced using acad 2000 and I am using acad 2004.
    150700
    3,434
    Default Re: unhandled access violation reading 0x0004 exception at 644fee80h
    Do you have the lastest service pack installed? I think doing this will solve that particular problem.
    13,656
    Hi
    Check out the following -
    fatal error: unhandled access violation reading 0x0004 exception at 644fee80h
    COPY PASTE FATAL ERROR
    As you're running and Autodesk 2004 (or 2005) product have you tried the following -
    <snip>
    Error Reporting utility let's you send in reports to Autodesk if AutoCAD crashes. Do it and make the next Service Pack or Release more stable. If AutoCAD ends unexpectedly, and the Error Report message is not displayed, make sure the REPORTERROR system variable is set to 1.
    </snip>
    Have a good one, Mike
  1. Ribbon - Unhandled access violation reading 0x0000 exception
    By erwin_van_eyken653432 in forum Dot Net API
    Last Post: 2013-06-18, 07:18 AM
  2. Unhandled Access Violation Reading 0x7eca48d4 Exception at 620663e4h
    By sebastien.212338 in forum Français - AutoCAD / AutoCAD LT - Général
    Last Post: 2010-01-22, 10:22 AM
  3. Unhandled access violation reading 0x0da4 exception at 36007973h.
    By arie.65266 in forum AutoCAD LT - General
    Last Post: 2009-07-19, 08:21 AM
  4. Replies: 4
    Last Post: 2006-11-22, 06:51 AM
  5. Unhandled Access Violation Reading 0x0020 exception at 633c4b5ah
    By scott.stokhaug in forum AutoCAD LT - General
    Last Post: 2004-06-09, 04:02 PM
