Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 65
Thread: AutoCAD Speak
  1. #51
    I could stop if I wanted to aaronic_abacus's Avatar
    2006-04
    419
    Default Re: AutoCAD Speak
    I finally implemented speakit.lsp in one of my programs!
    Works great!
    http://www.watsonlisp.com
    Artificial Intelligence for AutoCAD
    Find detail drawings by text and attribute content!
    6000 lines of code and and in development since 1997.
    Say goodbye to detail books.
  2. #52
    2006-04
    419
    Thankyou Terry for the awsome way to make autocad speak!
    I used it in one of my major projects.
  3. #53
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    I want to hide the command line and let it speak the prompts, (e.g. "Specify first point." etc.) Is it possible?
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
  4. #54
    2011-05
    This is to fun. Sorry had to.
  5. #55
    5,536
    More importantly... Which Windows Object controls the Volume / Mute setting?
    Edit: Found it! Settings.Mute
    Edit: Also helpful - Settings.Volume
    Mwaaatttaaaatttttaatttatataaaaaahhh!!!!
  6. #56
    2008-06
    8
    Quote Originally Posted by RenderMan View Post
    How to implement this in Lisp?
    Regards.
  7. #57
    5,536
    Quote Originally Posted by jaap.spierenburg View Post
    Edit: WARNING - Use at your own risk.
    Edit: Code revised such that the respective objects are supplied as an argument to reduce the number of time each is created and released.
    First, download the applicable version of nircmd.exe: 32 Bit, 64-Bit, More on nircmd.exe
    Second, use the applicable function for your needs:
    (defun MUTE  (oShell i / )
      ;; © RenderMan 2011
      ;; Example (mute <ShellObject> <Option>)
      ;; Arguments:
      ;;     <ShellObject>     "WScript.Shell" object
      ;;     <Option>         An integer of 0, 1, or 2
      ;;                 0=Unmute, 1=Mute, 2=Toggle
      (if (findfile "nircmd.exe")
        (vlax-invoke
          oShell
          'run
          (strcat "nircmd.exe mutesysvolume "
                  (itoa (fix i))))
        (prompt "\n** Cannot find \"nircmd.exe\" ** "))
      (princ))
    (defun SETVOLUME  (oShell vol /)
      ;; © RenderMan 2011
      ;; Example (setvolume <ShellObject> <Volume%>)
      ;; Arguments:
      ;;     <Volume%>     Real or integer equal to, or between 0 and 1
        (progn
          (vlax-invoke oShell 'run "nircmd.exe changesysvolume -65535")
          (vlax-invoke
            oShell
            'run
            (strcat "nircmd.exe changesysvolume "
                    (itoa (fix (* vol 65535.))))))
      (princ))
    Edit: There's a time and place for everything... even fun at the workplace:
    (defun TellUser  (string / *error* sayit oShell oSapi)
      ;; © RenderMan 2011
      ;; Example (TellUser "Hey, You! Get back to work. Hah zah!")
      ;; Arguments:
      ;;     string    Phrase to be spoken by Sapi.SpVoice object
      (vl-load-com)
      (defun *error*  (msg)
        (and oShell
             (setq oShell
                    (vl-catch-all-apply 'vlax-release-object (list oShell))))
        (and oSapi
             (setq oSapi
                    (vl-catch-all-apply 'vlax-release-object (list oSapi))))
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** "))))                 ; Fatal error, display it
        (princ))
      (defun sayit  (oSapi string /)
        ;; © RenderMan 2011, inspired by Patrick_35
        ;; Linky:    http://www.theswamp.org/index.php?topic=14549.0
        (vlax-invoke oSapi 'speak string 0)
        (princ))
      (if (and (setq oShell (vlax-get-or-create-object "WScript.Shell"))
               (setq oSapi (vlax-get-or-create-object "Sapi.SpVoice")))
        (progn
          (mute oShell 0)
          (setvolume oShell 0.50)
          (sayit oSapi string)
          (*error* nil))
        (cond (oShell (*error* "Could not create \"Sapi.SpVoice\" object"))
              ((*error* "Could not create \"WScript.Shell\" object")))))
    Happy coding!
  8. #58
    5,536
    Code revised, see comments above.
  9. #59
    2006-04
    419
    Does anyone know how to control the gender of the voice?
  10. #60
    5,536
    Not gender specific, but consider using the Voice Property of the SAPI.SpVoice Object.
  1. Replies: 0
    Last Post: 2015-08-07, 04:03 PM
  2. Speak 4 cad
    By maa in forum Software
    Last Post: 2006-06-30, 12:13 PM
  3. speak to autocad
    By jaberwok in forum Software
    Last Post: 2005-11-09, 08:12 PM
