Results 1 to 10 of 13
Thread: "Curve"-Based Families
    2005-07
    3,250
    2
    Thumbs up "Curve"-Based Families
    You'd like one of those, wouldn't ya?
    Well, I'm happy to post this experimental version...not used for anything specific, but it's potential application is only limited by your imagination! What prompted me to do this was the need for a "fire tape" along curved walls and the need for a generic model "curve" based family to model canopies (curved in plan) on the fly.
    First, I had to get my math straight, then I had to go through the hurdles of parametric radial arrays (thanks to all AUGI members that helped out with that portion). At least I remembered the crucial trigonometric concepts to work out all the formulas I needed, which are essential for this
    In the posted example, the family works very much like when drawing a curve....you click the start and end and then click the middle of the curve. Using this family, you don't click the third point. You just stretch the center up and down using the draggable handles. The array adjusts accordingly and is dependent on the "Maximum Span" parameter. The Maximum Span is the arc length between two arrayed members. The parameter "T" is the perpendicular distance between the line defined by the start and end point and the middle of the "curve". You're basically varying this parameter by dragging the arrows/handle at the middle of the curve. Or you can choose to type it in the properties window.
    Hope you find use for this concept and feel free to adapt for your use. I know I'm thrilled
    2001-07
    Phoenix, AZ
    1,003
    Default Re: "Curve"-Based Families
    Sounds great! Can't wait to play with it tomorrow. Thanks!
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    wow this rocks. Great job!
    2001-12
    Irvine, CA
    7,563
    Indeed, we all bow down to the recently annointed "Count (formula)"
    2005-07
    3,250
    You guys, you're making me blush
    100 Club jamie.casile80054's Avatar
    2004-12
    rock in the middle of the Pacific
    191
    very cool.
    Jamie Casile
    CAD/BIM Manager
    Pacific CADD Services, Inc.
    ...My Lomography Page...
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    753
    This is not working on non-Detail families for me. Does anyone have a Generic model (or some other non-detail) parametric radial array sample?
    2005-02
    Central PA, USA
    753
    Nevermind... I got it... I had changed my generic family to workplane based at some point, after I changed it back all worked great with parametric flute representation on my columns.
    2009-03
    Chicago, IL
    24
    very nice indeed.
    2010-07
    Very nicley done,
    Wonder if we can use this to do the Arched soldier Coursing.
    Thank you for the post.
  1. Replies: 0
    Last Post: 2013-05-06, 01:28 AM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. Add functionality similar to LDTs "Attach Multiple" line/curve command.
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-10-06, 01:59 AM
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 04:21 AM
  5. Line Based Detail: "Generic Curve-Driven Component"?
    By dbaldacchino in forum Revit Architecture - Families
    Last Post: 2006-08-05, 04:38 PM
