Thread: emergency fixture, annotation problem
    2009-01
    196
    Default emergency fixture, annotation problem
    I have an emergency light that has half the annotation hatched. The fixture is connected to both normal and emergency circuits. In the model, everything appears fine. When i print, the hatching on these fixtures does not appear. Any thoughts?
    MHWagner
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: emergency fixture, annotation problem
    We had this issue - ours contained a solid hatch and we typically make our Light Fixture Category yellow. We printed with 'Black Lines' but hatch did not show up. Upon closer investigation, it actually did but it was extremely faint because it was still following "yellow" instead of obeying the 'Black Lines' option.
    If that's not it, have you tried switching the plot settings from Raster to Vector, or vice-versa?
    Corey D.Please let the saying "The only stupid question is the one not asked" not be seen as a challenge to defy it.
  1. 2014: Annotation of Sloped Lighting Fixture Families
    By sweiler323390 in forum Revit MEP - Families
    Last Post: 2014-08-26, 02:39 PM
  2. 2012: Emergency!! CODE LEVEL ! HELP!!! Lighting fixture voltage change and keeping a circuit
    By steven.talbott538104 in forum Revit MEP - Families
    Last Post: 2012-11-02, 09:06 PM
  3. battery emergency fixture
    By malachi constant in forum Revit MEP - General
    Last Post: 2011-12-06, 11:56 PM
  4. Lighting Fixture Emergency Circuit
    By RobertB in forum Revit MEP - Families
    Last Post: 2009-11-13, 09:27 PM
  5. emergency light problem
    By mikemck in forum Revit Architecture - Families
    Last Post: 2005-11-06, 10:35 PM
