Results 1 to 9 of 9
Thread: Action Recorder save as to VB or C#
    Wish List Administration
    2011-08
    4,581
    Default Action Recorder save as to VB or C#
    Summary: Allow saving Action Recorded macros to VB or C#.
    Description: Allow saving Action Recorded macros to VB or C#. This would allow quicker customization and give developers a jump start on creating customizations with .NET
    Product and Feature: AutoCAD - API
    Submitted By: Kevin Kosak on Mon, 23 Apr 2012
    2015-12
    2,095
    Default Re: Action Recorder save as to VB or C#
    dotNET is pretty complex, and I suspect the Action Recorder storage mechanism is much closer to conventional scripting. I'd rather see it produce an XML metadata file describing the steps taken, plus (possibly) an Action Recorder API for dotNET for more complex manipulation. That way the XML content can be consumed by other operations, including LISP and manual tweaking and possibly even direct consumption by the new core console, and also be available from common network locations (unlike DLL; yes, I know about CASPOL but poking holes in the security for the sake of convenience isn't a good idea).
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    St. Paul, MN
    3
    What I was referring to would be something similar to what MS Office has called "Record Macro". "Record Macro" currently records to VBA format, which I beleive is considered obsolete. So, the next generation of such a utility seems to me would be to record to .NET VB or C#. Keep in mind users would not have to modifiy the .NET code but could.
    2011-08
    4,581
    Exclamation Re: Action Recorder save as to VB or C#
    Submitted By: Kevin Kosak on Tue, 12 Jun 2012
    2015-10
    Hi, That is a big wish for me as well. I need to automate things in CAD, but I have to record them first.
    2009-11
    5,536
    Quote Originally Posted by dgorsman View Post
    Not a big fan of this wish personally, as there's just too much variation of namespace qualification (within the body of code), etc to be 'usable' to my mind, and would entirely go against Autodesk's efforts to 'push' apps via Exchange.
    That said, regarding local/network assemblies - if you're still using .NET 4 (as I believe 4.5 supports this inherently, but have not intentionally tested for this since C3D 2011), just use LoadFromRemoteSources Attribute as Kean mentions here back in 2011:
    http://through-the-interface.typepad...ith-net-4.html
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2015-12
    2,095
    'Tis the season for necromancy
    Need to have DLLs local here, otherwise if any computer is running some of them would be locked "open" by the system and couldn't be replaced. Can't go around to computers to manually kick people out as we have multiple buildings across the city.
    2011-08
    4,581
    Submitted By: kpkosak on 04/23/2012
    2011-08
    4,581
  1. What do you use Action Recorder for?
    By mountpelepele in forum AutoCAD Action Recorder
    Last Post: 2017-10-10, 09:19 PM
  2. AU304-4: How to Get the Most Out of the Action Recorder
    By Autodesk University in forum AutoCAD
    Last Post: 2014-11-17, 05:33 AM
  3. 2012: Action Recorder and MTEXT
    By hwright185206 in forum AutoCAD Action Recorder
    Last Post: 2013-12-13, 05:23 AM
  4. add command in action recorder
    By e.mounir in forum AutoCAD Action Recorder
    Last Post: 2010-03-15, 08:25 PM
  5. Action recorder
    By Liamnacuac in forum ATP Course Wishlist
    Last Post: 2009-09-28, 05:55 PM
