Results 1 to 9 of 9
Thread: Block Scale Factor
    I could stop if I wanted to de-co1's Avatar
    2005-07
    Jhb - ZA
    272
    Default Block Scale Factor
    Hello All,
    LT2012
    I've been working on a drawing with an Xref'd grid containing grid lines and Steel columns. I noticed that the one column type is not the size it should be yet the scale factor is set to 1.
    Instead of a dimension of 209.6, it is measuring 209.59999990, and 205.8 measures 205.79999995.
    This happens with all my Universal beams and columns, but with no other block.
    When I insert these into a new drawing, they're fine, it's just with these particular drawings. And when I edit them in the Block Editor, they measure fine.
    Anyone come across this and knows how to remedy it.
    TIA
    David
    "Artists to my mind are the real architects of change, and not the political legislators who implement change after the fact."
    William S Burroughs
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Default Re: Block Scale Factor
    Obvious answer is that the entities in the Block are off that miniscule amount.
    Have you tried redefining the Block in the file that is causing problems?
    Are these Dynamic Blocks by chance?
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
    2005-07
    Jhb - ZA
    272
    I completely redrew the block of a steel universal column. Only a polyline and not dynamic. I've just completed a test on this too where I inserted the block into a blank drawing. Measurements are perfect. Copied it around a few times and still perfect.
    I then deleted these columns in the file I want to insert this block into, and purged that drawing completely, copied the information using a window (not crossing) and pasted this into the new drawing with the perfect block. Then the dimensions of the block changed again.
    The grid is positioned according to world coordinates.
    I discovered that the measurements change when I move the block to the WCS locations, but as soon as I move it back to my 0,0 origin, the dimensions revert back to the correct size.
    And when I move it to a point midway between 0,0 and the grid layout, the dimensions change by a factor of 0.00000001.
    So, the block change size the further away from 0,0.
    David
    William S Burroughs
    2009-01
    B5
    544
    Z problem here too perhaps?
    2005-07
    Jhb - ZA
    272
    Z-coordinates of all points in the block itself as well as the drawing it is inserted into, are 0...
    I drew a rectangle around the block while it was positioned at 0,0, moved both to the world coordinate location, and the rectangle changed in measured dimension too. But the rectangle didn't change if a drew it next to the block?!
    David
    William S Burroughs
    0,0,0 The Origin
    8,569
    Edit the block insertion, highlight the "1.000000" and type "1" and hit enter - do it for x, y and z values. Any change?
    John B
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    It happens when drawing is too far from the origin. There's a good explanation here in AUGI that have something to do with the limited number of decimal points (accuracy) and the program using trigonometric functions. Just search if you need it but that won't solve your problem.
    Try not to draw too far from the origin or draw in meters instead of millimeters (getting rid of three 0's).
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    Active Member davidmatyas's Avatar
    2005-01
    72
    Quote Originally Posted by de-co1 View Post
    Hello All,
    Make certain you are not pasting this into and you are inserting the block.
    Sounds suspicsiously(sp) like a rounding error. Could be hardware related (processor) Try another machine with diff. specs.
    Just suggestions, let us know. It's a nail-biter.
    David M. Matyas
    Matyas_COMP_Services
    2005-07
    Jhb - ZA
    272
    @Jaberwok: I did try that with no luck.
    @arshiel88: I can recall reading about this before, but wasn't able to find anything about it again, but if it is a case of what you suggest, then there doesn't appear to be anyway around it other than changing the Units. Unfortunately I cannot do that because the industry draws in millimetres.
    @davidmatyas: I was inserting my block. But doing it either way doesn't make a difference.
    It as arshiel88 pointed out... where it has to do with the distance from the Origin, which is also something we cannot really change as we are drawing in World Coordinates which forms part of our QA.
    Thanks for all your thoughts.
    David
    William S Burroughs
  1. ObjectDBX nested block scale factor
    By aruiz in forum AutoLISP
    Last Post: 2007-11-01, 04:30 PM
  2. Replies: 1
    Last Post: 2007-08-17, 12:37 AM
  3. Apply a scale factor to a scale action as you can with stretch actions?
    By Animal in forum Dynamic Blocks - Technical
    Last Post: 2007-01-24, 05:10 PM
  4. Block Unit - Scale Factor Sets Itself
    By michael.darwell in forum AutoCAD LT - General
    Last Post: 2005-09-30, 10:52 PM
  5. LDT Block Scale Factor
    By Beth Powell in forum Land Desktop - General
    Last Post: 2005-07-06, 05:58 PM
Tags for this Thread
