Thread: Listening Angular Dimension
    2011-10
    6
    Default Listening Angular Dimension
    Hi,
    When i draw a line or a wall, how i can enter the angular dimension?
    Thanks.
    2004-06
    Memphis TN area
    7,047
    Default Re: Listening Angular Dimension
    Good question, I have also wanted a way to enter an angle DURING object placement (after first pick in the case of a wall or line). If you start typing it goes to the length dimension. IMHO you should be able to hit Tab after you start typing to get to the angle dimension, but it doesn't work that way.
    AERC, PLLC
    Hernando, Mississippi
  1. 2014: Angular Dimension greater than 180°
    By bimaholic in forum Revit Architecture - General
    Last Post: 2014-03-27, 11:06 AM
  2. Apply Suffix to Angular Dimension
    Last Post: 2013-01-07, 03:39 AM
  3. 2011: Angular Dimension in IDW
    By elaforge in forum Inventor - General
    Last Post: 2010-07-06, 06:49 PM
  4. Listening dimension visibility
    By durentech in forum Revit Structure - General
    Last Post: 2009-10-27, 12:03 AM
  5. Angular Dimension Arrowheads
    By raddis in forum Revit Architecture - General
    Last Post: 2006-05-31, 03:56 PM
